Audio & Video not in sync after export
Rawad Rhayem
on Sep 14, 2012 at 1:03:14 pm
i am using final cut pro 6.06 and i have two sequences that are totally in sync but every time i export them i get a delay in audio. I export using quicktime settings and i've done it over 100 times before but this time is not working. i deleted the audio render files and copied the sequence to a new sequence and still not working. Anyone had this issue before and how did you solve it?
Chris Tompkins
Re: Audio & Video not in sync after export
on Sep 14, 2012 at 3:21:00 pm
What are you exporting to?
What are you playing the file off of?
A 10bit uncompressed HD file for example, will not play well off a single drive, you could experience lag in that case.
Chris Tompkins
Video Atlanta LLC
