Exporting Files
Eric Wendt
Exporting Files
on Sep 14, 2012 at 12:39:54 am
Here's the deal:
I imported a .mov file that was 68Mb. I needed to cut out some parts of the video that contained text/titles, so I cut those out and then nested the newly separated clips. This created a sequence. (I actually wanted to create a single clip out of these "merged" clips, but it created a sequence instead. Maybe this is part of my problem?)
In any case, I clicked on the new sequence and exported it using quicktime conversion. I chose H.264 as my format. I kept the frame rate and frame size the same, and I even exported with no sound. And still the exported file was more than twice the size of the original (only slightly modified) file.
Any ideas why this happened? In general, I'm trying to compress, not expand, the files I export.
Rafael Amador
Re: Exporting Files
on Sep 14, 2012 at 1:38:18 am
That, depending of the settings of the H264, the file can be very light or of the size of a full uncompressed 8b. Set Multipass, Key-frames AUTO and limit the data rate as you need.
rafael
http://www.nagavideo.com
