Equalizing
Andrew Zador
Equalizing
on Sep 13, 2012 at 6:29:04 pm
Hello.
Can someone please explain to me how I can equalize the volume of different clips, using Soundtrack Pro?
I need to increase the volume during speeches, without changing the background tone.
Thanks.
Jerry Hofmann
Re: Equalizing
on Sep 14, 2012 at 6:42:34 pm
Add a gain filter to the clips that you want to make louder. You can do it in FCP too.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Andrew Zador
Re: Equalizing
on Sep 14, 2012 at 8:34:28 pm
Thank you, but it is a little more complicated. I want to equalize several different clips with different level of background tones. I want the spoken words louder, while the background tone does not change, or changes very little.
Andrew Rendell
Re: Equalizing
on Sep 15, 2012 at 7:30:21 am
You could try using an expander effect, in principle you can set the threshold a little higher than the background noise and put more gain in for louder sounds, i.e., the speech. Alternatively, you could use an expander in noise-gate mode (or use a simple noise gate) to reduce the gain for sound below the threshold level, setting the gain for the speech manually, then mixing in some background noise on another track to even that out (because your gated track will sound rather unnatural if you don't).
Either way, my experience is that it's quite fiddly to find the sweet spot that sounds "right" though. TBH, keyframing gain levels can often get a better sounding result but that's enormously time consuming.
Good luck.
