.mov to Quicktime after already imported to FCP
Jacqui Hyne
on Sep 13, 2012 at 2:51:28 am
Hi
I have imported .mov files into FCP 7 and have been editing them but with obvious rendering problems. If I convert the files to Quicktime files and import them again, will I loose the editing work I have already done?
Thanks for your help.
Rafael Amador
Re: .mov to Quicktime after already imported to FCP
on Sep 13, 2012 at 3:42:26 am
If you don't say which kind of footage you are working with is impossible to suggest you what to do.
if you are talking about H264 stuff, yes, convert it to Prores before importing to FC.
rafael
http://www.nagavideo.com
Jacqui Hyne
on Sep 13, 2012 at 8:04:13 am
We newbies must be a right pain ;-)
I meant to say from H264 to Apple ProRes 422HQ. I was just concerned that I would lose all of the editing I have done if I reimport the files again after conversion - do you know if this would be the case?
Many thanks for your help.
Rafael Amador
on Sep 13, 2012 at 9:01:38 am
Is possible that you can not reconnect the files.
You should fallow those advices;
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
rafael
