How to overlay video on a moving target?
Soreyrith Um
on Sep 11, 2012 at 6:47:04 am
I'd like to overlay a video on top of another video of a cell phone, so that it looks like the video is actually playing on the cell phone. The problem is that the person holding the cell phone is moving his hand quite a bit, so I have to make adjustments using the distort tool on almost every frame. Is there some easier way to do this? I'd like to stay in FCP if possible because I know it best, but I also own Motion and AE. This is probably a fairly common problem, so there's probably a tutorial somewhere, but I just couldn't find one.
Shane Ross
Re: How to overlay video on a moving target?
on Sep 11, 2012 at 6:59:09 am
mocha for FCP
http://www.imagineersystems.com/products/plug-ins
Shane
Little Frog Post
Mark Suszko
on Sep 11, 2012 at 1:44:48 pm
If you don't want to spend money, Apple Motion has the tracking tool you need to make this work. Really, Motion in this context is very simple to use. Stephen Smith's tutorial DVD gives a great example.
Soreyrith Um
on Sep 11, 2012 at 3:29:22 pm
Thanks guys, for the quick replies. I'll check them out.
To make life easier, I was thinking of even just doing a freeze frame of the hand holding the phone, while the video is playing. But if it's fairly easy to do it with Motion or Mocha, then I'll give it a try.
Ross Shain
on Sep 12, 2012 at 5:25:56 pm
This is the kind of work that mocha excels at. If you own After Effects, than you already have mocha AE. It ships with AE CS4-CS6.
You can find lots of tutorials here and they are tagged by subject (FCP, Motion, etc): http://www.imagineersystems.com/videos?tagFilter=%25tutorial&sortBy=Newest
Here are a couple using the Apple Motion workflow:
http://www.imagineersystems.com/videos?tagFilter=import+to+Apple+Motion&sor...
To support FCP v7 or Apple Motion you can either buy mocha AEv3 or mocha Pro v3.
NOTE: Imagineer no longer sells "mocha for Final Cut" as a stand alone product. View the compare products chart here: http://www.imagineersystems.com/compare-products
Ross Shain
Imagineer Systems
