Codec not found. You may be using a compression type without the corresponding hardware card.
Marco Aguilar
on Sep 10, 2012 at 12:22:40 am
"Codec not found. You may be using a compression type without the corresponding hardware card. "
Not 100% sure what that message means. It happens when I try to render something or export something. Stops both processes.. My timelines settings are:
1920x1080
Aspect Ratio HDTV 1080i 16x9
Pixel Aspect Ratio Square
23.98
Compressor Apple Pro Res HQ
Where do I start poking around?
Shane Ross
Re: Codec not found. You may be using a compression type without the corresponding hardware card.
on Sep 10, 2012 at 2:12:07 am
Do you have any pictures in your sequence? If so, make sure they are RGB, and not CMYK.
Shane
Little Frog Post
