Issues Exporting to 1920x1080 in Compressor
Amy Lafleche
on Sep 9, 2012 at 5:20:08 pm
I am trying to convert video from multiple sources to an mov file with the following settings:
- Apple Pro Res HQ422
- uncompressed 10-bit
- 1920x1080
When I export it with the original dimensions it works fine, but when I try to change the dimensions to 1920 x 1080 it doesn't work. I don't get any errors. It runs through compressor, shows that it's complete, but there is no file to be found.
Thoughts on what's happening?
Chris Tompkins
Re: Issues Exporting to 1920x1080 in Compressor
on Sep 9, 2012 at 7:03:41 pm
When you say multiple sources....
What is your "Sequence" settings?
Make your sequence the settings you want.
Export using "Current Settings"
Done.
Chris Tompkins
Video Atlanta LLC
Amy Lafleche
on Sep 9, 2012 at 8:51:12 pm
I was able to solve the problem. It turns out the timeline was 1440 x 1080 - I recreated the project in 1920 x 1080 and was able to export.
