Juddering Video in FCP but smooth in other players
Josh Southam
on Sep 7, 2012 at 12:34:51 pm
HI,
Im having an issue with some MFX files which where converted to h.264.
They run smoothly on one machine IMAC 8gb ram i5 but when i try to play them back on a macbook pro intel core 2 duo 3gb ram the clips start to judder. I have monitored the cpu and its only running at about 50% during playback.
The other odd things is it works fine using some media players yet fcp seems to have a real problem with it on the macbook .
Any ideas as to what is happening and causing this?
http://www.rentacamuk.co.uk
02071126709
Rafael Amador
Re: Juddering Video in FCP but smooth in other players
on Sep 7, 2012 at 1:01:10 pm
[Josh Southam] "Im having an issue with some MFX files which where converted to h.264. "
FC do not supports H264. Some times works smoothly, some times makes the application crash.
For a solid workflow, convert the MFX to a more friendly codec. Prores is the best option.
rafael
http://www.nagavideo.com
