Creating a specific HD MPEG2 file
Michael Thompson
on Sep 5, 2012 at 6:06:37 pm
I'm having trouble figuring out how to create the following file for a client:
- All files must be delivered as elementary stream.
- Codec: MPEG2 ... Frame Size: 1920x1080 ... OAR: from 1.78:1 up to 2.35:1
... Frame rate: 50i ... Stream Type: MPEG2 Video Stream (Main Profile @ High Level)
... Field Dominance: Upper Field First .... Bit rate: not less than 50 Mbit/s CBR
... Chroma Format: 4:2:2
Certain specs I can find/create separately but not all together ... for example, trying to get 50Mbit/s CBR, I can only seem to find 40 at the most.
Now, the source files I'm using are as follows:
- Apple Pro Res, 25fps, 1440x1080, 48k 16bit
- Apple Pro Res, 25fps, 720x576 (16:9), 48k 24 bit
Do these need to be converted to 1920x1080 50fps before sending to Compressor or other software?
Files for client have to be MPEG2 ... cannot send them a .mov file
Using FCP 7.0.3 and Compressor 3.5.3
I deal more with dubbing and basic editing, so I'm not as well versed when it comes to digital conversions and codecs. Any suggestions would help ... thanks!
- Mike -
Rafael Amador
Re: Creating a specific HD MPEG2 file
on Sep 6, 2012 at 4:45:43 am
[Michael Thompson] "Certain specs I can find/create separately but not all together ... for example, trying to get 50Mbit/s CBR, I can only seem to find 40 at the most. "
That's the limit you can get in Compressor.
Any 50Mbps/422 option will be .mov.
To get what you want I think you need Telestream's "Episode Pro" (995$$).
Anyway I suggest you to ask in the "Compression Techniques" forum.
[Michael Thompson] "Now, the source files I'm using are as follows:
Do these need to be converted to 1920x1080 50fps before sending to Compressor or other softwa"
Compressor can do all the resizing while is transcoding.
rafael
http://www.nagavideo.com
