When to use 1920x1280 vs. 1920x1080?
jd mulvey
on Sep 4, 2012 at 9:37:47 pm
Hello all, I've been reading this forum for over a decade but posting for the first time.
I can't find any resources explaining when 1920x1280 would be used. I'm editing a video composed of stills scaled to 1920x1280. Since I plan to project the film, and my projector's native resolution is 1920x1080, I plan to crop, but wanted to check if I'm missing anything....is there any reason one would use 1920x1280?
Many many thanks for your help.
mulvey
Shane Ross
Re: When to use 1920x1280 vs. 1920x1080?
on Sep 4, 2012 at 9:48:39 pm
[jd mulvey] "I can't find any resources explaining when 1920x1280 would be used."
Never.
[jd mulvey] "I'm editing a video composed of stills scaled to 1920x1280."
Why? That's just plain wrong. !920x1200 I can see, but ONLY if you want to play back on a 24" monitor that has that resolution. Nothing I know of has 1920x1280.
[jd mulvey] "Since I plan to project the film, and my projector's native resolution is 1920x1080,"
If that's the case, why the HECK are you working at 1920x1280??
There is a 1280x1080 format. That is ONLY DVCPRO HD, and it is super-anamorphic. And FCP scales that to 1920x0180. But nothing I have ever heard of is 1920x1280.
How did you get that in your head?
(Please take my snarkiness with a grain of salt. It is meant in mirth)
Shane
Little Frog Post
jd mulvey
on Sep 5, 2012 at 3:03:17 am
Thanks for confirming my suspicion. I meant that I'm editing in 1920x1080.
I scaled down the stills I shot to be 1920 wide, which made them 1280 high. So I started googling 1920x1280 to see if that's a legit resolution and found many threads where people seem to be working with it, which confused me. So just wanted to confirm that I should indeed just crop the height, which I have.
Anyway, Thanks!
