Timelapse FC Settings
Eric Glidden
on Aug 31, 2012 at 3:36:51 am
I have about 10,000 high quality photos (shot with a DSLR) that I am going to edit into a timelapse video. Before I start I'd like to know the best settings on final cut for importing photos in order to make the clearest video (I've lost video quality in past videos). And then the best way to export it. I'd just be tossing it on Vimeo. Thanks.
Eric
Rafael Amador
Re: Timelapse FC Settings
on Aug 31, 2012 at 4:55:20 am
If you are going to Vimeo, make a 1920x1080, square Pixels, Progressive, Prores sequence.
25 or 30 fps, up to you.
You need to set "Still Duration = 1 frame" in the preferences. You should also increase the "Still Cache".
Make your edit, and before exporting, set "Render in High Precision" and "Render Motion Effects: Best".
rafael
http://www.nagavideo.com
Eric Glidden
on Aug 31, 2012 at 6:55:43 pm
Thats perfect. Thank you so much.
Eric
