Issues with the ai13 Codec in Final Cut Pro 6 and Quick Time
Amy Lafleche
on Aug 30, 2012 at 3:07:17 pm
I imported a timeline from Final Cut 7 to my Final Cut 6 using XML files.
I reconnected all the media except for one file which uses the ai13 codec. When I try to render the timeline I'm getting an error that says the Codec could not be found.
I installed the AVC Intra Decoder v1.5 and get the same error.
I also tried opening the raw file in Quick Time and got a similar error.
Here are the two screenshots with errors:
Suggestions? Any help would be appreciated.
Rafael Amador
Re: Issues with the ai13 Codec in Final Cut Pro 6 and Quick Time
on Aug 30, 2012 at 3:37:57 pm
I haven't found nothing about that codec in Google.
Try to open the file with VLC and see what happens.
rafael
http://www.nagavideo.com
Anna Ingenthron
on Aug 31, 2012 at 12:14:35 am
I believe this is an AVC-Intra codec. You'd have to use Log and Transfer if you have the P2 plug-in to bring it into the project. Not sure if you need to recreate a folder structure for the file.
Steve Eisen
on Aug 31, 2012 at 3:11:45 am
I can not guarantee that it will work in FCP 6.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
