Audio Tracks 3 and 4 Not Exporting Properly
Matt Hargrave
on Aug 30, 2012 at 8:50:01 am
I'm probably just missing something simple here but I can't figure out how to get one project to properly export audio tracks 3 and 4. I have the sequence set to 4 outputs, dual mono each, with no downmix. When I bring the exported QT back into FCP all 4 tracks are there but there is no audio on tracks 3 and 4. Everything seems to be set up the exact same as another project which exports all 4 tracks fine. What could I be missing? I've attached a picture of my audio tracks in case there is something I'm missing there.
Michael Gissing
Re: Audio Tracks 3 and 4 Not Exporting Properly
on Aug 30, 2012 at 8:54:04 am
Right mouse click on each track near the lock icon and check patching. Each track needs to be patched to an output and my guess is you have them patched to 1&2 which is the default
Matt Hargrave
on Aug 30, 2012 at 9:03:25 am
Yep, that did it. Can't believe I forgot such a simple step. Thanks for the help.
