When super-imposed text disappears image jumps?
Gavin Williams
on Aug 29, 2012 at 7:14:42 pm
I have my final edit, I then create a new sequence and drop the finished edit sequence into the new sequence and put some text atop the opening scene. As the text ends the image jumps almost like it is repeating a frame?? Driving me crazy?? Anyone help on this?
Gavin
Miriam Lefkowitz
Re: When super-imposed text disappears image jumps?
on Aug 29, 2012 at 7:31:05 pm
Are you sure the sequence was rendered?
Gavin Williams
on Aug 29, 2012 at 7:41:26 pm
Yep - it's definitely rendered
Anna Ingenthron
on Aug 29, 2012 at 8:03:35 pm
Did you try quitting, trashing preferences, trashing renders and re-rendering, restarting, etc.?
If you export that section, does the jump happen in your quicktime?
Eric McCarthy
on Aug 29, 2012 at 10:10:03 pm
[Anna Ingenthron] "
If you export that section, does the jump happen in your quicktime?"
This is my 1st question as well. Also, did you try supering the text as a .PNG/.PSD file?
Michael Gissing
on Aug 29, 2012 at 10:10:48 pm
What are your sequence settings (codec, frame rate etc) and what are your clip settings?
An educated guess is that you might be using a non FCP edit codec like h264.
Tom Matthies
on Aug 30, 2012 at 1:42:42 pm
Wrong frame ordering possibly?
E=MC2+/-2db
