Can anyone tell me how to read the Document "Final Cut Pro System ID"?
Sherry syb
on Aug 29, 2012 at 5:18:01 pm
Library -> Application Support -> ProApps -> Final Cut Pro System ID
This is were the serial number is housed but I don't have a application that will open it.
My mac has failed so need to rebuild from scratch but do not have a serial number. only got Final Cut Pro System ID which i want to decode for serial number
Shane Ross
Re: Can anyone tell me how to read the Document "Final Cut Pro System ID"?
on Aug 29, 2012 at 5:20:37 pm
YOu can't. But if you launch FCP, the application splash screen shows the serial number. Just take a screen shot of that.
Or look in your documentation for the number.
Shane
Little Frog Post
Sherry syb
on Aug 29, 2012 at 5:25:24 pm
my system has already crashed cannot launch FCP. i am trying to retrieve the Final Cut Pro System ID, so that once i re-build and install FCP then can insert serial number if able to decode this file?
Shane Ross
on Aug 29, 2012 at 6:01:09 pm
Just move the system ID to the new install. YOu know where to find it. Take it and put it back after you do the fresh install.
Shane
Little Frog Post
