mix footage: fps 25 + fps 30 - convert 30fps to 25fps
antania corti
on Aug 29, 2012 at 11:03:35 am
Hallo,
I am editing a short reportage shot mostly with 25fps.
However, I will have to add to it some 30fps footage.
The final product has to be 25fps.
How woud you suggest me to proceed?
Many thanks!
Antania
Shane Ross
Re: mix footage: fps 25 + fps 30 - convert 30fps to 25fps
on Aug 29, 2012 at 5:22:38 pm
Convert all of the 30fps footage to 25fps before you edit. Use Compressor, and turn the frame controls up to BEST. And then wait a day or two (depending on how much footage) while it compresses this to match.
Shane
Little Frog Post
antania corti
on Sep 1, 2012 at 8:33:26 pm
Hallo Shane, thanks for your advice.
I converted the 30pfs footage,using ocmpressor but now I have an audio problem. The footage is longer therefore I need to speed it up..but the result is a good video with a unusuable audio.
I think I have choose some wrong parameter for the conversion...?
