Sequences in Duplicate Projects
Matty Smith
on Aug 21, 2012 at 7:56:34 pm
I'm working on a project made up of a series of very similarly set-up videos (they all use the same assets, etc.). I've got a template project file with multiple sequences, and I'd like to be able to just open the template, "Save Project As...", and then edit for each individual video.
My question is about whether I'll need to rename the sequences for each individual project as well, or if once I've saved the whole project as a separate file the sequences are specific to that one and only project save. My worry is that I'll change a sequence in a later project and that'll somehow affect a sequence in an earlier saved project.
Thanks in advance for your response!
Dave LaRonde
Re: Sequences in Duplicate Projects
on Aug 21, 2012 at 8:47:44 pm
You shouldn't have any problem at all using the same sequence names in different project files.
It goes without saying you'll want the files exported from them to either be in a new folder or use a different file name.
...and so I said it anyway. Go figure.
Dave LaRonde
Sr. Promotion Producer
Shane Ross
on Aug 21, 2012 at 9:10:32 pm
NO matter what project they are in, the sequences will be exported with the sequence name. So you might want to be careful about that.
Shane
Little Frog Post
