Footage from a DSLR and another video camera
Lawrence Richards
on Aug 16, 2012 at 4:08:38 pm
I'm working on a project that necessitates the mixing of footage from a DSLR and an HVX200a. Is it possible to do a multi-cam edit with footage from these two different sources?
Thank you!
Larry
Thank you!
Larry R.
Florida
Rafael Amador
Re: Footage from a DSLR and another video camera
on Aug 16, 2012 at 4:40:43 pm
No.
All the stuff must have the same specs.
rafae
http://www.nagavideo.com
Shane Ross
on Aug 16, 2012 at 5:03:31 pm
Convert both to ProRes with the exact same frame dimensions. This might be tricky as the HVX shoots DVCPRO HD and that it anamorphic. Just make sure that you choose the proper dimensions in Compressor to convert them.
Shane
Little Frog Post
Lawrence Richards
on Aug 17, 2012 at 12:32:41 am
Darn. Thanks though!
Thank you!
Larry R.
Florida
