Is this external drive adequate to edit from directly?
Mark Suszko
on Aug 14, 2012 at 2:52:55 pm
Sam's Club was blowing out these 2-terabyte external drives for a hundred bucks. I got one initially for just a backup archival use, but I wonder if I can edit FCP projects using it as a scratch drive, feeding my new imac via usb3.
It's a Seagate free agent go flex 2 TB. No specs are listed. Thoughts?
Steven Cohen
Re: Is this external drive adequate to edit from directly?
on Aug 14, 2012 at 3:08:27 pm
If it is this one..
http://www.amazon.com/Seagate-FreeAgent-GoFlex-External-STAC2000100/dp/B003...
Then most likely it is not going to be able to edit directly.
It is just a USB 2.0 connection which won't handle the data transfer needed to edit, especially if you are doing any HD.
Steve.
Shane Ross
on Aug 14, 2012 at 3:29:26 pm
I think they need to list their specs! Even on the website they don't list the speed of the drive. Because of this, I suspect that they are putting in 5400RPM drives, and touting these only as backup.
But try it out and see. I too am looking for a USB 3 drive to test using as a media drive.
Shane
Little Frog Post
Mark Suszko
on Aug 14, 2012 at 4:10:25 pm
It touts a USB 3 connector, which is what got me thinking about it as a scratch drive... for non-critical home movie type usage.
