extremely slow export/freezing
Fred Hazelhurst
on Aug 14, 2012 at 4:29:42 am
hey there, I'm using FCP6 to edit a sequence of fairly hi-res images and I've encountered some problems. I tried exporting it using different Quicktime conversion settings in FCP6, and with Compressor, but both times I get an unusually long export time (around 7 to 8 hours, which fails after about 3) or in the former's case the export percentage freezes at about 10%. I managed to get this out of one of the recent error logs but I couldn't find any google results for it:
Status: Failed: 3x Source file /private/var/folders/ir/ir+6nejbE+upAv7cQAZ9N++++TI/TemporaryItems/33747D33-D30E-42B5-B73C-B7.fcp not found
Source file mediaserver:///private/var/folders/ir/ir+6nejbE+upAv7cQAZ9N++++TI/TemporaryItems/33747D33-D30E-42B5-B73C-B7.fcp;appSignature=com.apple.FinalCutPro%26itemname=1%26framerate=25%26in=0%26out=35581%26nativeCodec=dvcp%26nativeCodecMfr=appl%26displayName=53657175656E636520312D686F6D6D36%26width=720%26height=576%26startTC=25.000000%2090000%20NDF%26fieldDom=3%26channelLayout=6619138%26sampleRate=48000 is not directly accessible.
hope this is enough information, I'm really tripped out by this problem. Also I tried trashing my preferences, which has worked for glitches in the past, but not this time.
