Exporting problem
Arvid Utas
Exporting problem
on Aug 13, 2012 at 8:15:30 pm
Hello people, how are you?
This is my problem:
I have a 5gb large h264 .mp4 file that I need to do some minor changes to. When I import it into FCP the program says "General error" and then "Error: out of memory" and I cant see the project in the canvas. Still I managed to do what I needed to do blindly and I don't know if the memory issue matters for my problem. What happens is that when I have exported the project (Export - Quicktime movie) it doesn't play smoothly. The camera movement appears jittery.
What can I do to avoid this?
Help would be rewarded with great appreciation and good karma!
jerry wise
Re: Exporting problem
on Aug 13, 2012 at 8:29:19 pm
convert your file to prores422 using mpeg streamclip and then edit.
Shane Ross
on Aug 13, 2012 at 9:23:39 pm
Or use an editing app that works with that file format natively, like Adobe Premiere Pro
Little Frog Post
© 2018 All Rights Reserved
