Transfer HDMI to iMac
Kenn Schulz
on Aug 12, 2012 at 6:38:30 pm
How would I transfer HD1080i from Sony FX7 into my iMac. Should files be ".mov" or should they be "ProRes"? -KS
Shane Ross
Re: Transfer HDMI to iMac
on Aug 12, 2012 at 7:19:34 pm
Firewire...
Choose the HDV 1080i60 Easy Setup, and capture as HDV. OR, use this trick to capture as ProRes:
http://library.creativecow.net/articles/poisson_chris/hdv-prores.php
YOu can only capture HDMI to the iMac if you have an iMac with Thunderbolt, and a video IO device from AJA, Blackmagic or Matrox.
Shane
Little Frog Post
