Pro Res 422 HQ Question?
Jonny Cates
on Aug 10, 2012 at 4:20:20 pm
I mistakenly checked the HQ position while sizing several formats into 1280 x 720 Pro Res 422.
When layering these formats on the timeline, it seems the HQ is causing some playback problems - like a slow motion jerky effect. I do have Unlimited RT selected too.
But if I select lower playback rates, they will then play OK. But of course the Dynamic resolution is gone.
"Can I re-transcode these same Pro Res HQ files - but this time without the HQ?"
Or do I have to go back to the original files to redo? Is this because of the HQ was selected, or is there something else going on?
Thanks....
Jonny Cates
jerry wise
Re: Pro Res 422 HQ Question?
on Aug 10, 2012 at 5:32:49 pm
What is your Sequence Setting.?
Jonny Cates
on Aug 10, 2012 at 6:25:50 pm
Jerry; settings are....
Frame size: 1280 x 720 HDTV 720p (16:9)
Pixel: Square
Filed Dominance: None
Timebase: 30
Compressor: ProRes 422 (HQ)
100%
Audio:
48kHz
16-bit
Channel Grouped
Jonny Cates
