Working with 59.94 frame rate and 23.98 on same sequence
carlos dee
on Aug 6, 2012 at 11:32:12 pm
hello, im working on a project thats 1920x1080 23.98, there is a piece that i recorded at 1280x720 @ 59.94 frames that i want to add to the project thats at 23.98 and slow it down smoothly, how can i do this? everything was recorded with a canon mark 3 dslr, when i was recording it i chose 2 different rates on my camera for the 2 different clips i wanted to record my main project is at 23.98 i hope this makes sense, im uaind the 422(HQ) conversion
when i made an extra sequence on final cut and added the 59.94 clip to it and slowed it down on there then added the slowed down sequence to my main project i got an error that i cant have different editing timebases how can i add the 59.94 clip to my 23.98 project and have it slowed down smoothly thanks!
Mac Pro 12Core 2.4
12GB Ram
2TB SSD
Mac OSX 10.6.8
Quadro 4000 & ATI 5770
Shane Ross
Re: Working with 59.94 frame rate and 23.98 on same sequence
on Aug 7, 2012 at 12:44:16 am
Either use Magic Bullet Grinder to convert the footage to ProRes and while doing that, resize it to 1080 and convert the frame rate to 23.98 smoothly.
Or...
Convert the footage to ProRes and use Cinema Tools to slow it down:
http://library.creativecow.net/ross_shane/slow-motion_cinema-tools/1
Shane
Little Frog Post
