Field dominance problems with files from Blackmagic
Ornulf Riisnes
on Aug 6, 2012 at 12:23:11 pm
I record video (PAL) with Blackmagic media express 3.3.2. When playing the .avi-files in Final Cut i get a field dominance problem. The shift fields filter does not solve this. Anybody with experience on how to solve this?
-O.
Doug Weiner
Re: Field dominance problems with files from Blackmagic
on Aug 22, 2012 at 12:40:44 pm
I too am having this problem. The solution although not a good one is to use compressor. Here a droplet.
<a href="http://f1.creativecow.net/4572/field-switch-droplet-for-black-magic-intensity-for-use-in-compressor">4572_correctfieldswitch.setting.zip</a>
Doug Weiner
on Aug 22, 2012 at 12:41:36 pm
Doug Weiner
on Aug 22, 2012 at 12:42:45 pm
Doug Weiner
on Aug 22, 2012 at 12:49:44 pm
Ok, someone delete all those posts with the link and please give me clear directions how to upload a file. (Or if an Admin can just fix it, that would be great.)
In the meantime, here are the text instructions to create the same droplet in Compressor:
Frame Control ON:
Resize: Fast
Output Fields: Top
De-interlace - Fast
no adaptive details
Anti alias - 0
Details level - 0
Rate Conversion Fast
Set Duration - 100% of Source
Then in the Video Settings
Frame Rate: Current
Gamma Correction None (although no matter what I get the gamma shift)
Interlaced: Top Field
Enable Chroma filtering for 4:4:4 off.
