Compressor export off 1 frame in 23.98. but export works in fcp
max slomoff
on Aug 6, 2012 at 4:01:03 am
hello,
i'm noticing an issue with compressor and 23.98 footage. when i transcode a prores file to a proxy the timecode changes by one frame. (duration is the same, but the start and end frames are 1 framed later than the original)
any ideas how to fix this?
thanks,
max
Olivier Aubut
Re: Compressor export off 1 frame in 23.98. but export works in fcp
on Sep 27, 2012 at 3:08:30 pm
Hey
I don't have a solution, but I have the same problem.
It seems to be a problem with compressor 4 because I never had this issue before upgrading from compressor 3.
Olivier
