HD Quality Control????Output HD to monitor live editing
Grant Strac
on Aug 3, 2012 at 5:36:42 am
I recently changed jobs from HD for web to broadcast what the hell do I have to buy to hook up like a canopus box? I have a sd one but I can't find any equivalent for HD video output to QC monitor. It's frustrating me because I know its in my face but I can't find device on BH.
Shane Ross
Re: HD Quality Control????Output HD to monitor live editing
on Aug 3, 2012 at 7:16:13 am
aja.com
decklink.com
matrox.com/video/en/products/
Shane
Little Frog Post
Grant Strac
on Aug 11, 2012 at 4:00:58 pm
Ok but I'm working with tape less system. I have a Canopus breakout for sd that just firewired in and had outputs. Do you know the best device for tape less hd editing?
Shane Ross
on Aug 11, 2012 at 5:15:32 pm
Your firewire options for HD are limited. VERY limited. AJA IoHD works with Final Cut Pro 6 and 7 only, and runs $3500...if you can find it. The MOTU V4HD is $2000.
If you have Thunderbolt connectors, then you have better options. Decklink Intensity Shuttle and Intensity Extreme are both under $300. The Matrox MXO2 Mini is $500. Those all work with Avid/FCP/FCX/Adobe.
If you have an iMac with no Thunderbolt...you are out of luck. If you have a laptop with Express34, there is the AJA IO Express ($1000), and Matrox MXO2 Mini. If not...if only firewire, then the first option I list is all that's available.
What computer do you have?
Shane
Little Frog Post
Grant Strac
on Aug 13, 2012 at 3:00:41 pm
Mac pro 6 8-core 2012 no thunderbolt :(
Shane Ross
on Aug 13, 2012 at 5:20:17 pm
No, that's fine. Get the Decklink Intensity Pro. $200. HDMI out.
http://www.blackmagicdesign.com/products/intensity/models/
Shane
Little Frog Post
Grant Strac
on Aug 18, 2012 at 12:00:14 am
Thank you so much for your advice. I greatly appreciate you taking the time out. Have great one man
