Need to export JPEG2000 in MXF wrapper
Cade White
on Aug 2, 2012 at 10:36:07 pm
I need to export a 30 minute show as a JPEG2000 in a MXF wrapper. We on the latest Mac Pros and have access to FCP7 or FCPX. We could also use Premiere Pro CS6 if needed.
Any ideas?
Cade White
Re: Need to export JPEG2000 in MXF wrapper
on Aug 3, 2012 at 3:44:07 am
I have learned that the station where this show will run is using a Maxx 1200 HD system.
Shane Ross
on Aug 3, 2012 at 5:15:47 am
Well, apparently it isn't easy...
http://community.avid.com/forums/p/60111/336750.aspx
http://forums.creativecow.net/thread/20/865962
Still unsure how to do it. Wonder why it is so hard to do.
Ahhh...
http://www.digital-rapids.com/Products/IndividualProducts/Stream%20Software...
Shane
Little Frog Post
Cade White
on Aug 3, 2012 at 5:45:35 am
Thanks for the links. Searching this and other forums I've found several threads addressing this problem....none with a real clear solution.
The Digital Rapids products look quite capable but it appears they're all windows only. Unfortunately, we are Mac-only and adding new hardware isn't an option.
And, to complicate this even more, the solution we end up with needs to support closed captioning.
Frustrating...
Rafael Amador
on Aug 3, 2012 at 9:51:33 pm
Have a look to those link:
http://hamburgpromedia.com/
http://www.reduser.net/forum/archive/index.php/t-44480.html
rafael
http://www.nagavideo.com
Joseph Owens
on Aug 7, 2012 at 8:40:58 pm
Rafael's second URL will probably be more useful, as it sounds like you're being asked to make a DCP.
Getting trendy.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
Cade White
on Aug 7, 2012 at 9:26:34 pm
Has anyone tried the MXF export suite from Hamburg Media? http://home.mxf4mac.com/shop.html
Kim Rowley
on Mar 27, 2013 at 8:23:19 am
Hi Cade,
I have the exact same need (Export a Jpeg2000 file with MXF wrapping). Have you made any decisions since your last post? I have been using the MXF4Mac plugins from Hamburg Media for the past few years (exporting in IMX50) with no apparent issues. Our shop is starting to digitize legacy DigiBeta tapes using the Digital Rapids encoder but I need to know how to do the same with new edited programs from FCP.
How are you fairing?
Kim
2x 2.4 GHz Quad-Core Intel Xeon 12GB RAM, ATI Radeon HD 5770, Xserve RAID, AJA IO, 2 Cinema Display, FCP Studio 3 (7.0.3), OS X10.6.5
Kai von Garnier
on Jul 16, 2013 at 2:29:52 pm
Hello Kim,
since e do have a JPEG2000 Importer, we are working an Exporter as well.
I hope, we can release this year
Best regards
Kai
