FCP 7 Dropped Frames after trashing Prefernces
Jim Cooke
on Aug 2, 2012 at 6:24:15 pm
I've read a ton of other answers for this same question. I was having issues after rendering footage so I trashed Preferences. When I restarted FCP i get dropped frames during playback. I am working with AppleProRes LT sequence settings match the clip. The footage is on an external Glyph raid. I reset capture scratch to that drive. When I open FCP now i get "External A/V Unable to locate the following External devices, Apple Firewire NTSC 720x480" i click check again and nothing. Please any help is greatly appreciated. I am not a super pro.
That warning was not happening prier to trashing preferences
The dropped frames issues was not happening prier to trashing preferences
Jessica Muth
Re: FCP 7 Dropped Frames after trashing Prefernces
on Aug 2, 2012 at 9:15:57 pm
Check your user preferences. Make sure you don't have the "Report Dropped Frames" option checked.
There is also an option within Audio/Video Settings in the very last tab that allows you to report the External Video error.
Jessica Muth
jmuth01@gmail.com
Rafael Amador
on Aug 3, 2012 at 12:24:25 am
[Jim Cooke] "I was having issues after rendering footage so I trashed Preferences. When I restarted FCP i get dropped frames during playback. I am working with AppleProRes LT sequence settings match the clip. The footage is on an external Glyph raid."
And where are the render files?
[Jim Cooke] " When I open FCP now i get "External A/V Unable to locate the following External devices, Apple Firewire NTSC 720x480" i click check again and nothing."
If you donĀ“t have any FW external device (Camera or VCR), uncheck "Warn next time" when you get the message.
rafael
http://www.nagavideo.com
Jim Cooke
on Aug 3, 2012 at 2:36:01 pm
Render files are on the same external drive. Which I thought would be powerful enough. I unchecked the Report dropped frames which seems to have solved the constant warning.
Jim Cooke
on Aug 3, 2012 at 2:33:57 pm
I did have it checked, thanks!
