NTSC DV Sequence was used for a 1080i 60 video
Kevin Techmeier
on Aug 1, 2012 at 12:16:58 am
I did not see this in the FAQ. I finished editing a video, but upon exporting to tape (print to video), it said my sequence settings did not match the tape deck settings. I looked at the timeline settings, and it was set to a NTSC DV with anamorphic checked.
I tried to create a new sequence with the proper settings, but as I pasted the clips to the timeline, the picture is now super small on the canvas. If I render it, will it conform the new sequence settings, or is there something else I need to do?
FCP 6.06
Thank you for your time!
Shane Ross
Re: NTSC DV Sequence was used for a 1080i 60 video
on Aug 1, 2012 at 12:46:57 am
HIGHLIGHT all the clips...right click and choose REMOVE ATTRIBUTES. Basic Motion and Distort need to be what you remove. That will make them fit the screen. Now, if you did any repositioning of footage, this will undo that, and you will need to redo them.
Shane
Little Frog Post
Kevin Techmeier
on Aug 1, 2012 at 1:54:42 am
I will do that. Thank you for your input!
