Boris title 3 D window
Monica F.P.Williams
on Jul 31, 2012 at 1:01:28 am
Hola ! I have a problem , usually when i open boris with an extra monitor the pop up window appears in my second screen. If i use my laptop with no second Monitor boris still open its window in a monitor that is not there!!!
So i get stuck because fisically i cant click ok on the window to close it! How do i fix this?
Any suggestions?
Monica F.P.williams
crocodile editing
web: http://www.crocodileediting.com
Rafael Amador
Re: Boris title 3 D window
on Jul 31, 2012 at 9:37:23 am
[Monica F.P.Williams] "usually when i open boris with an extra monitor the pop up window appears in my second screen."
Drag the window to the main screen and close the window. Next time should open in the main screen.
if the problem persists, try trashing FCs preferences.
rafael
http://www.nagavideo.com
Monica F.P.Williams
on Aug 3, 2012 at 7:18:56 pm
Thank you, it worked! Sorry for not reply right away (very busy week)
Monica F.P.williams
crocodile editing
https://vimeo.com/crocodileediting
The "EARTH" without "ART" is just "EH"
