Final Cut Pro 7.0.3 SD field issue
Joao Rodrigues
on Jul 29, 2012 at 3:15:54 pm
Hi Everybody,
Does anyone could me help with the following issue.
I'm shooting in about 5 different HDs codec but my end copy will be analog Betacam, a already tested a lot of different down conversions log and transfer to SD compressor to SD, BlackMagic realtime hardware downconversion it is the best result but I loose some resolution, all others downconversions the fields like dominance inverted. what workflow do you suggest to get best downconversion for Betacam SP?
Chris Tompkins
Re: Final Cut Pro 7.0.3 SD field issue
on Jul 29, 2012 at 6:51:50 pm
SD is never gonna look as good.
Your best bet I think, is to edit in HD and use the bmd card to feed the beta with a down convert.
Chris Tompkins
Video Atlanta LLC
Rafael Amador
on Jul 29, 2012 at 8:57:50 pm
[Joao Rodrigues] " all others downconversions the fields like dominance inverted."
I guess you are mastering in Prores.
Remember that If you are in PAL land your master must be Upper first.
Lower first for NTSC land.
rafael
http://www.nagavideo.com
Paul Jay
on Jul 30, 2012 at 10:28:38 am
Edit in HD ProRes..
Convert HD ProRes to SD ProRes in Compressor ( SET RESIZE FILTER TO BEST )
Dump to Betacam from FCP
Joao Rodrigues
on Jul 30, 2012 at 10:53:26 pm
Thank you guys! For your time!
