FCP reading 24 fps clips (ProRes) as 10 fps?
Kees van Dijkhuizen
on Jul 28, 2012 at 8:47:35 am
Hi guys, I'm new here.
I have 10 clips or so in ProRes LT format with a framerate of 23.98 / 24 fps. When I open them in FCP, I get a verry jittery image because FCP recognizes it as 10 fps. The audio seems fine though: it plays the entire clip. But more than half of my clip is gone because FCP can't even reach there.
Any ideas? They're quite long clips, like 2 hours each.
Thanks.
Kees van Dijkhuizen
Re: FCP reading 24 fps clips (ProRes) as 10 fps?
on Jul 28, 2012 at 9:03:33 am
Hi guys, I actually figured it out.
What you need to do is take the clip into Cinema Tools and conform it to 23.98 fps. For some reason, Cinema Tools reads it as 23.80, but when you conform it, FCP takes that data and plays it back normally.
Shane Ross
on Jul 28, 2012 at 9:11:40 am
Yes, this is what you need to do when you do screen captures with Camista or SnapzPro. They don't seem to lay down a proper timecode track, so FCP reads it wrong. Cinema Tools fixes that.
Shane
Little Frog Post
