FCP Crash Report Assistance
Caleb Theimer
on Jul 18, 2012 at 10:30:13 pm
FCP has continued to crash on me. Unfortunately, I don't understand how to read the crash reports whatsoever. This is one of the many crash reports that I am getting quite often. I have trashed the system preferences several times, but that doesn't seem to help. If someone could take a look at this and let me know what is causing this problem, it would be greatly appreciated. Thanks!
Process: Final Cut Pro [9332]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.3 (7.0.3)
Build Info: FCPApp-1008261348~8
Code Type: X86 (Native)
Parent Process: launchd [177]
Date/Time: 2012-07-18 17:17:11.442 -0500
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 98618 sec
Crashes Since Last Report: 3
Per-App Interval Since Last Report: 83032 sec
Per-App Crashes Since Last Report: 3
Anonymous UUID: 93E7BAB5-6EDF-4A19-B687-FBE48D3E39B5
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libGLImage.dylib 0x071bf4cf void glgConvertTo_32(GLGOperation const*, GLDPixelMode const*) + 254
1 libGLImage.dylib 0x0719f352 glgProcessPixelsWithProcessor + 2436
2 GLEngine 0x186f667d glGetTexImage_Exec + 2234
3 libGL.dylib 0x048a5854 glGetTexImage + 59
4 com.apple.ProGraphics 0x4a076f3a PGTexture::getData(void*, unsigned int, unsigned int) const + 106
5 com.apple.ProGraphics 0x4a077215 PGTexture::toBitmap() + 277
6 com.apple.ozone.framework 0x492d0ba2 GLRenderer::renderImageFromNode(HGNode*, OZRenderParams&, HGRenderer*) + 3042
7 com.apple.ozone.framework 0x492d224a GLRenderer::render(OZScene*, OZRenderParams&) + 2714
8 com.apple.ozone.framework 0x493763e4 OZXGetFrame + 2644
9 com.apple.ozone.framework 0x49378f16 OZXGetFrameAsBitmap + 86
10 com.apple.motion.component 0x0f8aadd9 0xf8a9000 + 7641
11 ...ple.CoreServices.CarbonCore 0x03bafdcc CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
12 com.apple.motion.component 0x0f8ab5fa OZQTCodecComponentDispatch + 202
13 ...ple.CoreServices.CarbonCore 0x03ba851f CallComponentDispatch + 29
14 ...ickTimeComponents.component 0x17002600 ImageCodecDrawBand + 43
15 ...ickTimeComponents.component 0x1693fcab BaseCodec_DecompressWorkFunction + 1002
16 ...ickTimeComponents.component 0x1694042d BaseCodec_DecompressCallBack_Common + 1328
17 ...ickTimeComponents.component 0x16942107 Base_CDBandDecompress + 5449
18 ...ple.CoreServices.CarbonCore 0x03bafdcc CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
19 ...ickTimeComponents.component 0x1693d5ab Base_CDComponentDispatch + 127
20 ...ple.CoreServices.CarbonCore 0x03ba851f CallComponentDispatch + 29
21 com.apple.QuickTime 0x01314caf ImageCodecBandDecompress + 43
22 com.apple.QuickTime 0x01302dfe DoBandedDecompress + 17559
23 com.apple.QuickTime 0x012fe779 ICMAction + 1177
24 com.apple.QuickTime 0x012fd388 ICMDeviceLoop + 546
25 com.apple.QuickTime 0x013062fc DecompressSequenceFrameWhen + 714
26 ...ickTimeComponents.component 0x1682d2c4 v2m_rDecompressSequenceFrameWhen + 1092
27 ...ickTimeComponents.component 0x16830576 v2m_decompressVideoFrame + 609
28 ...ickTimeComponents.component 0x1683411a QueueAFrame + 1595
29 ...ickTimeComponents.component 0x1683501a v2m_doWhatTheMentorTellsUs + 1243
30 ...ickTimeComponents.component 0x168388b7 Video2MoviesTask + 2891
31 ...ple.CoreServices.CarbonCore 0x03bbb095 callComponentStorage_44444 + 49
32 ...ple.CoreServices.CarbonCore 0x03bafdcc CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
33 ...ickTimeComponents.component 0x16825d95 Video2ComponentDispatch + 212
34 ...ple.CoreServices.CarbonCore 0x03ba851f CallComponentDispatch + 29
35 com.apple.QuickTime 0x01358696 MediaMoviesTask + 61
36 com.apple.QuickTime 0x01357453 TaskMovie_priv + 4847
37 com.apple.QuickTime 0x0136a1f8 MoviesTask_priv + 101
38 ...alCutPro.Plugins.QTM Reader 0x19218c1b LongGOPChunkWriter::receiveSample(unsigned char const*, long long, unsigned long, long long, long long, SampleDescription**, unsigned long, unsigned long, long long, bool) + 22009
39 ...alCutPro.Plugins.QTM Reader 0x19229095 PluginMainEntry(long, long, KGDictInt*, void*) + 7555
40 com.apple.FinalCutPro 0x00245edb pKGGetFileVideo(KGDictInt*, double, long, unsigned char, KGCanvasRec*, KGRect*, KGDictInt*, KGFileRec*, unsigned long long, long) + 1615
41 com.apple.FinalCutPro 0x0024d876 GetItemFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 728
42 com.apple.FinalCutPro 0x0024f13e GetSpeedFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 3556
43 com.apple.FinalCutPro 0x0024f4d9 GetFilterFrame(KGDictInt*, KGClipItemType, long, unsigned char, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 897
44 com.apple.FinalCutPro 0x00250888 DoVImageMotion(KGDictInt*, KGClipItemType, KGMotionPointInstance*, BufferInfoRec*, KGCanvasRec*, KGRect*, int, KGFieldType*, unsigned char, KGRect, KGRect, KGRect, unsigned char, renderStackInfo*, WhenRec*, double, unsigned char*, KGFloatPt*, KGFloatPt*, KGRect*, CGAffineTransform*, KGAffineTransformQuality, unsigned char*) + 178
45 com.apple.FinalCutPro 0x00252e63 GetMotionFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 5137
46 com.apple.FinalCutPro 0x0025509f GetBlurFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 2627
47 com.apple.FinalCutPro 0x0025660f GetTrackItemFrame(KGDictInt*, TrackInfoRec*, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 5473
48 com.apple.FinalCutPro 0x0024c7bc CompositeLoop(KGDictInt*, WhenRec*, KGCanvasRec*, KGRect*, BufferInfoRec*, renderStackInfo*, unsigned char*, TrackItemAtTimeCache*) + 1704
49 com.apple.FinalCutPro 0x0025801a pKGGetClipVideoWithAlpha(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 5408
50 com.apple.FinalCutPro 0x0024b541 pKGGetClipVideoWithAlphaMulticlip(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 281
51 com.apple.FinalCutPro 0x0045e748 GetVideoFromRenderEngine(XXGlobals*, Output*) + 878
52 com.apple.FinalCutPro 0x0046252a DecodePipeTree(XXGlobals*, Output*) + 184
53 com.apple.FinalCutPro 0x0042bd65 FCPMediaHandler::RenderFrames(long long, bool) + 3981
54 com.apple.FinalCutPro 0x0042c0b0 FCPMediaHandler::Preroll(long, long) + 250
55 com.apple.FinalCutPro 0x0042c137 FCPMHPreroll(FCPMediaHandler*, long, long) + 31
56 ...ple.CoreServices.CarbonCore 0x03bafdcc CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
57 com.apple.FinalCutPro 0x00426221 FCPMHDispatch(ComponentParameters*, char**) + 59
58 ...ple.CoreServices.CarbonCore 0x03ba851f CallComponentDispatch + 29
59 ...ickTimeComponents.component 0x16ffecf6 MediaPreroll + 49
60 ...ickTimeComponents.component 0x1687848d GenericPreRoll + 61
61 ...ple.CoreServices.CarbonCore 0x03bafdcc CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
62 ...ickTimeComponents.component 0x1687afbe GenericComponentDispatch + 182
63 com.apple.FinalCutPro 0x0042623d FCPMHDispatch(ComponentParameters*, char**) + 87
64 ...ple.CoreServices.CarbonCore 0x03ba851f CallComponentDispatch + 29
65 com.apple.QuickTime 0x0137358e MediaPreRoll + 49
66 com.apple.QuickTime 0x01373521 prerollMedia + 85
67 com.apple.QuickTime 0x0132d01e ForEachMedia_priv + 82
68 com.apple.QuickTime 0x013730a2 PrivatePrerollMovie_priv + 147
69 com.apple.QuickTime 0x01372ff8 PrerollMovie_priv + 42
70 com.apple.QuickTime 0x01372fc3 PrerollMovie + 36
71 com.apple.FinalCutPro 0x001ce19c DoSetRateSetup(KGPlayerRec*, float, unsigned char, unsigned char) + 820
72 com.apple.FinalCutPro 0x001ce693 DoSetRate(KGPlayerRec*, float, unsigned char) + 289
73 com.apple.FinalCutPro 0x001d12ca pKGPlayerPlayToWithRender(KGPlayerRec*, double, double, long, float, KGLoopStyle, unsigned long) + 3502
74 com.apple.FinalCutPro 0x001cf612 pKGPlayerHandleDefaultMenu(KGPlayerRec*, long, unsigned long) + 1492
75 com.apple.FinalCutPro 0x001cfa5b pKGPlayerHandleDefaultMenu(KGPlayerRec*, long, unsigned long) + 2589
76 com.apple.FinalCutPro 0x001d7290 pKGClipDefaultMessage(long, long, KGDictInt*, KGDictInt*, long) + 1012
77 ...Pro.Plugins.Timeline Editor 0x192b5f70 TLTimeRemapGetChangeType(KGDictInt*, KGItemSpec*, double, KTPartKind, long) + 102226
78 com.apple.FinalCutPro 0x002b1ae1 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 2103
79 com.apple.FinalCutPro 0x0025e872 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 120
80 com.apple.FinalCutPro 0x0025fd1c TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 110
81 com.apple.FinalCutPro 0x002a7781 pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
82 com.apple.FinalCutPro 0x002bd5a3 pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 91
83 com.apple.FinalCutPro 0x0015099b HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 417
84 com.apple.FinalCutPro 0x00150b11 HandleCommand(long, unsigned char, unsigned char, unsigned char) + 263
85 com.apple.FinalCutPro 0x0015695a HandleKeyDown(OpaqueEventRef*, KGDictInt*, KGWindowRec*) + 1404
86 com.apple.FinalCutPro 0x001587a1 DoEvent(OpaqueEventRef*, KGDictInt*) + 3117
87 com.apple.FinalCutPro 0x00414501 Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 67
88 com.apple.HIToolbox 0x06749c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
89 com.apple.HIToolbox 0x06748ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
90 com.apple.HIToolbox 0x06748d55 SendEventToEventTargetWithOptions + 58
91 com.apple.HIToolbox 0x0677d60b ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1957
92 com.apple.HIToolbox 0x0674a080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
93 com.apple.HIToolbox 0x06748ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
94 com.apple.HIToolbox 0x0676b7f3 SendEventToEventTarget + 52
95 com.apple.HIToolbox 0x068f4c17 ToolboxEventDispatcher + 86
96 com.apple.HIToolbox 0x068f4d4f RunApplicationEventLoop + 243
97 com.apple.FinalCutPro 0x001539d1 KGMainEvent(void*) + 51
98 com.apple.FinalCutPro 0x002c1278 main + 54
99 com.apple.FinalCutPro 0x00002d5b _start + 209
100 com.apple.FinalCutPro 0x00002c89 start + 41
