General Error or Out of Memory Continued Frustrations
John Orchard
on Jul 18, 2012 at 6:24:20 pm
Hi everyone! I've been searching this forum and have done the solutions provided in some of the workarounds, i.e. deleted preferences etc. I'm still having the same issue: I export a 60 second 1920x1080 QT animation codec sequence from After Effects CS6, import into FCP 7.0.3 and mix audio. I then try to export directly from the timeline, File>Export>Using Quicktime Conversion. Almost immediately I get the "General Error" or "Out of Memory" error. I've tried re-exporting out of AE to no avail. Incredibly frustrating. If I export 1280x720 from AE and try the same thing I get no problems however. What gives? I need this to be full HD. Please help!
MacPro 2x2.4 ghz quad
64GB RAM
NVIDIA Quadro 4000
John
jerry wise
Re: General Error or Out of Memory Continued Frustrations
on Jul 18, 2012 at 8:04:52 pm
i would run your animation codec thru Compressor and convert to ProRes 422HQ.
Bret Williams
on Jul 18, 2012 at 11:47:21 pm
64 GB RAM??? Wow. What are you doing with an old MacPro that you are coming close to even needing 1/4 of that? Time to eBay some of that while it's still gold. :)
