How do I shift all markers in Final Cut Pro?
Matthew Davies
on Jul 16, 2012 at 10:59:13 pm
I have a whole bunch of DVDSP chapter markers all set up in an FCP sequence. However, I want to add a little 5 second splash screen at the beginning of the sequence. How do I shift all the chapter markers so that they aren't all off when I add the splash screen?
Shane Ross
Re: How do I shift all markers in Final Cut Pro?
on Jul 16, 2012 at 11:04:30 pm
Do an INSERT EDIT and they should move down. If you have them set to RIPPLE. And this only works if you have FCP 7.
Shane
Little Frog Post
Matthew Davies
on Jul 16, 2012 at 11:06:07 pm
That would be it! Thanks so much!!! You saved me!!!!!!!!!! :-)
Matthew Davies
on Jul 16, 2012 at 11:08:00 pm
Now that I've solved that, I do have another question. How do I copy a section of video and the chapter markers associated with them?
Shane Ross
on Jul 16, 2012 at 11:09:10 pm
You don't. The markers are either on the clip, or on the sequence. They aren't connected.
Shane
Little Frog Post
Matthew Davies
on Jul 16, 2012 at 11:09:47 pm
That's what I figured. Thanks anyway!
