Audio drift issue!
Ben Bloom
Audio drift issue!
on Jul 16, 2012 at 4:01:59 pm
I've read through a few forums but haven't had any luck with solutions provided. I've got an audio drift issue, occurs very quickly, the audio is off within seconds of the sync point.
Working with-
Final Cut 7
Video-initially cut in DV then reconnected to H.264. All video is 29.97 frames. Audio at 48khz.
Audio- initially as an mp3 at 44.1 khz. I converted it to a wav in iTunes and set it at 48khz.
No green bars at the top when I throw the audio into the timeline, so the frame rates seem to harmonize.
This is a video for a musical performance. I've done 5 other tracks from the same show with the same workflow, and nothing like this happened before. The audio of the performance seems much, much slower then the video. I'm sure I missed some key information on my specs for you guys to help, but if you ask me to elaborate, please try and specify what other information you're looking for.
© 2018 All Rights Reserved
