5DtoRGB conversion corrupts GH2 footage into thermal cam
Ramez Silyan
on Jul 12, 2012 at 6:47:44 pm
Every time I try to convert specific clips, the program completes the job, but the end result is this thermal cam black image with red light deal. When I use Clip Wrap, the files convert just fine, but the 5DtoRGB outputs better quality overall so I want to figure out the problem.
Settings are as follows on the 1.5.9 (64 bit)
output: ProRes 422
encoding: ITU-R BT .709
Luminance: Broadcast Range
Chroma: Default
Gamma: 0
the clips are 720p 60i
any help would be greatly appreciated. thanks!
Shane Ross
Re: 5DtoRGB conversion corrupts GH2 footage into thermal cam
on Jul 12, 2012 at 7:15:49 pm
Could be that the 5DtoRGB app is designed for Canon DSLRs...and not Panasonic GH2s. The name says it all.
Every camera manufacturer employs slightly different versions of the codecs. And that is maddening.
Shane
Little Frog Post
Ramez Silyan
on Jul 12, 2012 at 7:19:05 pm
i have friends who have used the program with their GH2 perfectly fine... i dont think that is quite it.
Michael Gissing
on Jul 13, 2012 at 1:44:50 am
720p 60i? I guess you mean 60 frame not 29.97 interlaced.
I suspect Shane might be right about the software not being desinged for that camera and it may be specific to that frame rate & frame size.
Do your friends have success with 720p 60 or 1080 29.97p?
Gary Huff
on Jul 16, 2012 at 3:45:53 am
[Michael Gissing] "I suspect Shane might be right about the software not being desinged for that camera and it may be specific to that frame rate & frame size."
No, it's not right. I use 5DtoRGB with GH2 footage all the time and it looks fantastic.
Michael Gissing
on Jul 16, 2012 at 3:52:48 am
Are you converting 720 60p Gary?
Thomas Worth
on Jul 13, 2012 at 2:17:40 pm
Hey Ramez, are you able to convert clips from other cameras successfully? You might try to transcode a clip from a 5D or 7D to ensure the problem isn't related to the GH2 footage. Also, if you want to send me a still frame of what you're seeing, I'd like to have a look at it.
