Final cut pro 7 reconnect media to new media with different specs
lisa segal
on Jul 10, 2012 at 2:16:20 am
I created a project with a low res video clip in FCP7. After the final edits, I made my original low res clip offline, then reconnected it to a new high res video clip (identical content, just much higher res). I assumed that I could then copy all the footage from the low res sequence and paste the clips to a new sequence set up with the proper specs. When I do this, I get video that is not fitting properly to the new sequence. Is there a simple way to do this?
Bouke Vahl
Re: Final cut pro 7 reconnect media to new media with different specs
on Jul 10, 2012 at 5:13:54 pm
Change your sequence settings to match the new format?
Bouke
http://www.videotoolshed.com/
smart tools for video pros
lisa segal
on Jul 10, 2012 at 5:46:56 pm
forgive my ignorance as I use Adobe and my partner is the one with Final Cut Pro 7, how does one change sequence settings to match footage?
Bouke Vahl
on Jul 11, 2012 at 12:03:31 pm
right click the sequence and choose ' settings '
If you are unsure, make an empty sequence, drop in one clip.
FCP will ask you if you want the sequence to be set to the clip settings. Answer yes, and note the settings made for you.
Bouke
lisa segal
on Jul 11, 2012 at 6:11:59 pm
Thanks, correct answer, all is good now.
Lisa
