Revert from Multiclip?!
Henry DeMaio
on Jul 7, 2012 at 8:31:42 pm
Hello all, I'm cutting a narrative short right now and have run into some issues. I was brought into the project late so was not in contact with the assistant editor when he built the project in FCP7. He set the whole project up as multiclip, even though there are only two angles (at most) to cut between. I never work in multiclip, I just don't like the interface and it seems unnecessary to me, so I was dismayed when I saw the project had been set up this way, but figured I'd give it a try since there's a pretty tight deadline.
I'm coming up against some huge issues, probably due to my lack of familiarity with multiclip. Rather than try to have you guys sort these issues out for me, as there are many, I'm curious, is there any way to separate multiclips? Can I go into a timeline and somehow make all the multiclips appear as separate video and audio?
Also, here are my specs, just in case:
OS X 10.7.4
iMac
3.4 Ghz Intel Core i7
16 GB ram
AMD Radeon HD 6970M 1024M
FCP 7
Thanks for any help you can give.
Henry
