Discrete Audio Channels for H.264 Compression
Aaron Barton
on Jul 5, 2012 at 4:20:20 pm
Hey guys,
So I'm trying to make a Quicktime H.264 with 8 channels of audio from a Quicktime ProRes HQ file that has 8 discrete audio channels. The problem I'm having is that when I bring the HQ file in to Compressor, it shows up as stereo and not having 8 discrete channels of audio. Is there a way to change the way Compressor interprets the file it's about to compress?
Aaron
Tina Hedegaard
Re: Discrete Audio Channels for H.264 Compression
on Jul 6, 2012 at 8:18:51 am
Hi aaron
If you choose AAC in audio settings, then you will have more options. Hope it helps.
Cheers
Tina Hedegaard
Editor | Assisting Editor
Final Cut Pro 7 | Media Composer 5.5.3/6.0.1.1
Mac OS 10.6.8| Mac OS 10.7.4
Tina Hedegaard
on Jul 6, 2012 at 8:20:46 am
Or actually you can also choose the PCM (better audio) and you will have even more options
Cheers
Tina Hedegaard
