Moving edited text from After Effects into FCP !?
alex bunderburg
on Jul 5, 2012 at 12:35:21 pm
I edited text on After Effects, and want to use it in my Final Cut Pro 7 movie.
How do I export the After Effects to Final Cut Pro?
Stephen Smith
Re: Moving edited text from After Effects into FCP !?
on Jul 5, 2012 at 10:39:08 pm
Export the comp out as a Prores 4444 or Animation if you want to keep the background transparent. Be sure to set the Channels to RGB + Alpha. Then make sure depth is set to Millions Color +. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
