MXF into FCP
dan crouch
MXF into FCP
on Jul 4, 2012 at 8:23:50 am
Can anyone please help with this.
I need to import 200 MXF clips into FCP.
From reading past post's, it seems I need to covert them first.
Can anyone help regarding this conversion. Would 'i media converter' be the best thing?
I need to batch process them.
Any help would be very much appreciated,
Dan.
Shane Ross
Re: MXF into FCP
on Jul 4, 2012 at 8:31:40 am
MXF from...? P2 camera? Canon XF? Canon C300? If so, Log and Transfer is what you use...tutorial here.
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
You will need drivers for Canon XF and C300 if those are the cameras.
Or is it MXF from some other source?
Shane
Little Frog Post
dan crouch
Re: MXF into FCP
on Jul 4, 2012 at 8:40:16 am
Thanks for post Shane.
It's a c300.
Cheers,
Dan.
Shane Ross
Re: MXF into FCP
on Jul 4, 2012 at 6:22:00 pm
Then you need to load the XF log and transfer plugin from Canon (google it), and use...well...Log and Transfer.
Shane
Little Frog Post
