Lay to tape with alpha channel?
Ceri Allen
on Jul 3, 2012 at 10:11:33 am
Hi
I just want to know if it is possible to lay off to tape (HDCam) with an alpha channel included for graphics?
And how would I go about this, I presume the sequence settings would need to be apple pro res 444?
Ceri
Greg Leslie
Re: Lay to tape with alpha channel?
on Jul 3, 2012 at 2:37:24 pm
Ceri -- HDCam doesn't support an alpha.
Usually, graphic elements that need to be keyed are layed off in two passes: a matte pass and a fill. The matte is just the black/white-shades-of-gray alpha element, and the fill has been modified to correctly show transparent pixels when keyed.
You give the tape to someone, they re-digitize the matte and fill (or copy them to another tape deck), sync them up and use the former to key the latter.
hope this helps,
Greg Leslie
Tulsa
Doug Beal
on Jul 3, 2012 at 2:43:05 pm
In the old days we'd lay off the fill and the matte as two separate layoffs that could be later injested and keyed. Unless you have an HDCamSR 4444 will not be possible in one pass.
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
Mark Suszko
on Jul 3, 2012 at 3:11:18 pm
We cheat this by putting the elements over a chromakey green background when laid to tape. Then key it at the other end. You coudl also use white or superblack (zero IRE on your scope) and later do a change of blend mode, or a luma or even difference key, depending on how complex the element is.
