Adding .scc file to mpeg program stream in Compressor
Tom Matthies
on Jul 1, 2012 at 2:35:04 am
I'm trying to add a .scc closed captioning file to a ProRes sequence I'm converting to mpeg within compressor. I have a self contained ProRes 720x486 Quicktime file. I'm bringing that into compressor and converting to a pretty much standard mpeg 2 file for broadcast. I'm attaching the .scc in the "Additional Information" tab under the "Closed Caption File" option. I select the .scc here and submit in Compressor as normal. An mpeg2 file shows up shortly after. Fotta love Quick Cluster! What a time saver.
However, the resulting mpeg2 file doesn't seem to have any closed caption information embedded in it. I'm looking at it in Quicktime Player Pro v7.7 with the Closed Caption component installed. I also have a standard Closed Caption decoder but this will only read the 608 variety of CC. Am I making a faulty assumption that I can add CC info to the mpeg data stream through compressor? The manual seems to indicate that adding a .scc file this way should result in a 708-compatitable data stream in the resulting mpeg2 file.
I'm looking to deliver a weekly show as an mpeg2 program stream rather than delivering it on tape. The show is shot in HD but edited in SD due to many of the network stations being unable to air the show in HD at the moment. It should be ready to deliver in HD next season so I'm looking for a workflow to embed the CC info. Actually, will 708-type captioning work in a SD file?
Anyone have any insights into this methodology?
Also, where did the Compressor forum go, anyway?
E=MC2+/-2db
Rafael Amador
Re: Adding .scc file to mpeg program stream in Compressor
on Jul 1, 2012 at 3:39:16 pm
Tom,
I have no idea about CC, but I've been reading a little bit and seems that QT Player can't read the CC.
Try VLC to see them.
Have a look to this thread:
http://forums.creativecow.net/thread/279/752
and the linked article:
http://chrisduke.tv/973/close-captioning-videos
rafael
http://www.nagavideo.com
Art Morgan
on Jul 3, 2012 at 7:13:14 pm
Tom, hopefully you already saw this, but a couple of us replied on your other thread about how to use Compressor for HD captions:
http://forums.creativecow.net/thread/279/863
Chris Duke describes his workflow in detail here:
And I created a similar video tutorial here:
Art Morgan
Automatic Sync Technologies
http://www.automaticsync.com
Robert Lowry
on Jan 28, 2015 at 4:19:13 pm
I am trying to add .scc file using compressor 3.5.3 but doesn't seem to work. I have followed at least two tutorial from you tube but still not success. Do we need a newer version of compressor? I read how easy it is to do but we are not having any luck. Please help/advise>
R.L. Lowry
