FCP 7 relinking question
Ben Edwards
on Jun 30, 2012 at 1:19:38 pm
I have a project where I have a media managed version but want to link back to the non media managed footage as the 2 second handles are not enough (doing major edits). This has actually worked surprisingly well (although time consuming as I have to locate each clip manually). My question is after manually relinking does FCP remember the new media file names so if I move the non media managed media will relinking be easy.
For example I have a clip called bob and the media managed media was called bob-1. I can manually link to the non media managed media (called bob). If I then move the bob media and reconnect the media will FCP look for bob or bob-1?
Ben
Ben Edwards - Freelance Picture Editor
http://www.funkytwig.com
Macpro1,1 2007 6GB RAM 2*2 3Ghz Xeon
Bret Williams
Re: FCP 7 relinking question
on Jun 30, 2012 at 6:12:19 pm
Bob.
Shane Ross
on Jun 30, 2012 at 7:10:27 pm
If you media managed and the new files are not exactly the same length as the originals...if they are selects with handles...those will not relink to the original full-sized clip without third party app help.
You've said you've done this before without issue?
Shane
Little Frog Post
Ben Edwards
on Jul 2, 2012 at 12:09:57 pm
Yes, seems to work fine. It does complain about media start/end but it seems as long as the media in the clip exists in the media file it relinks, even if the media is longer.
I do have to locate the clips manually but as I said in the MM project if the blip is called bob-1 then I try the fill clip called bob and it works.
Ben
