File size shrinks after Log and Transfer??
Chris Jones
on Jun 30, 2012 at 12:51:24 am
Just curious..
I have Log and Transferred 2 64GB P2 cards in FCP7 that were full (the even wrote over to the second card in my camera)
After I logged and Transferred the MXF to MOV files with FCP I have found that what were 63ish GB sized CONTENTS folders are now 51ish GB sized folders filled with all the MOV files.
I thought maybe they were compressed, but when I compare any single MXF file to its MOV file copy, the MOV file is slightly larger - which was a relief - since I don't want any compression.
But I am curious why the overall folders are smaller after the L&T.
Anyone know?
Shane Ross
Re: File size shrinks after Log and Transfer??
on Jun 30, 2012 at 1:16:57 am
There are other files on the P2 card that might not come over, like ICONs and PROXYS. And if you recorded 8 channels of audio, but only imported 2...that might be it.
Shane
Little Frog Post
Chris Jones
on Jun 30, 2012 at 2:27:41 pm
[Shane Ross] "d if you recorded 8 channels of audio, but only imported 2...that might be i"
That made sense until I checked it and they were the same!
But then it dawned on me. I shot at 1080 24PA. I'm guessing the advanced pulldown would reduce the overall sized of the data I shot?
Shane Ross
on Jul 1, 2012 at 6:55:57 am
Yes...it will remove frames....thus the file size will be smaller.
Good catch.
Shane
Little Frog Post
