Importing Still into FCP
Jess Reynolds
on Jun 28, 2012 at 7:41:16 pm
Hi there
I have a number of time lapses shot on the 5D that I need to import into FCP. Is there a way to set the duration of the stills (like you can in avid) so that when I import a folder of stills they are only 1 second long. Right now they are 10 seconds long.
Many thanks
Jess
Mark Suszko
Re: Importing Still into FCP
on Jun 28, 2012 at 8:24:40 pm
Yes, you set this in user preferences:
see here it is set to ten sec. change that to one second, use a brand new bin for each set of stills. Stills should be in the 0000 format, so image one is 0001, then 0002, etc. or else they can get out of order in the timeline.
