FCP 7 Stops Responding during Playback
Ron Whitestone
on Jun 27, 2012 at 5:28:57 pm
I just finished about 17 minute project. I did some color work and then just finished up my work from Sountrack Pro. I brought the XML file back into FCP and after opening up the sequence FCP now stops responding. I get the spinning rainbow wheel and it won't go away. I try to restart the program and it happens again and again. This is the first project this has ever happened on. Any ideas what could be wrong so that I don't lose all the work I just did?
My stuff is saved and opens back up perfectly fine and then the "Application Not Responding."
That's the info from the report I get when I close the program.
Event: hang
Duration: 8.00s (sampling started after 2 seconds)
Steps: 39 (100ms sampling interval)
I've figured out that it only happens when I try to playback my video. When I open the project I can edit, render, save, export, ect... but but once I press space to play back my timeline it stops responding and doesn't catch up.
I already trashed my preferences and that didn't work.
Thanks in advance for any help!
© 2018 All Rights Reserved
