Deliverable question - NTSC
Aaron Walker
on Jun 26, 2012 at 11:52:10 pm
Hello,
I have a client wanting an NTSC digibeta of a film shot and cut in 1080p 23.98. It doesn't specify required framerate for the NTSC. Should I assume it's 29.97? Can you even have an NTSC 23.98 digibeta? The reason I ask is that the closed captioning will need to be done twice if I have to have both a 23.98 and a 29.97 version, since the timecode will be different when synced to audio. Probably a silly question but I don't dabble in deliverables much.
Thanks.
Andrew Kimery
Re: Deliverable question - NTSC
on Jun 27, 2012 at 12:24:44 am
Yeah, it's 29.97.
Shane Ross
on Jun 27, 2012 at 12:25:38 am
[Aaron Walker] "Should I assume it's 29.97?"
Yes, because NTSC Digibeta only does one frame rate...29.97. SD doesn't do 23.98.
[Aaron Walker] "Can you even have an NTSC 23.98 digibeta?"
Nope.
[Aaron Walker] "The reason I ask is that the closed captioning will need to be done twice if I have to have both a 23.98 and a 29.97 version"
Yes it will. Been there, done that.
Shane
Little Frog Post
